Hello yrij063,
I am sorry, but the schematic is working very well.
What is your problem?
Have you set the Fuses for the Atmega8 in the right way?
High Fuse 0xC9, Low Fuse 0x9F
Which type of optocoupler is fitted (6N136/6N137)?
For 6N136 Pin 7 is not connected
For 6N137 Pin 7 is connected to 5V
Some hint's:
1. To use with Multimaus, pleas use Switch Address 5 and above for first servo ( connect one Servo to Position 1 and one Servo to Position 5 and try switch-adr 1,5,9)
2. The LED is sometimes blinking and sometimes not, I do not know how and why??
3. The Multimaus could not read CV's in stand alone mode
4. CV's are in the range from 1 to 120 or 512 to 632 for Multimaus please use 1 to 120 and see Manual
5. Jumper off -> Decoder A Servo 1-4, Jumper on -> Decoder B Servo 5-8 (or vice versa)
6. Both Decoders using the same CV-Addresses, selection is done by Jumper
7. change R2 to 10K (330R is to strong!!)
8. change R3 to 1k5 or 2k2 (see http://opendcc.de/elektronik/HW1/platine_v12_schaltung.jpg)
Regards
ruhri
Some hint's:
Regards
ruhri
